Should a rev 2 3S-GE have 2 radiator fans?
mattbearman
Post by mattbearman »
As the title says, should a rev 2 3S-GE have 2 radiator fans?
I'm planning to replace the radiator anyway, but today I noticed there's only one radiator fan, and an unused connector next to it :?
almeida1234
Re: Should a rev 2 3S-GE have 2 radiator fans?
Post by almeida1234 »
Only if you got aircon
mattbearman
Thanks for the info. Mine definitely doesn't have AC, odd that there's a connector hanging by the rad
almeida1234
I believe it's part of the loom from factory.
SonicSW20
Post by SonicSW20 »
Yep. If you look in your engine bay you'll see a couple of plugs not connected to anything - they are for the air-con.
It's cheaper to have one production making one loom and paying a couple yen extra for unused connectors that it would be to make separate looms for for every configuration.
mattbearman
I did wonder about the spare engine bay plugs, but a few people have pointed out that Toyota used the same wiring loom no matter what spec or market the car was. Makes sense :thumleft:
