So I've been mooching around in the engine bay of the recently purchased Mk2 and came across this EGR setup. Has this been blocked off correctly as it looks a bit bodged?
Also, what could the microswitch arrangment be that is fixed to the EGR blank plate? It has 2 spade connectors and a contact piece which touches the throttle spindle bracket thingy when the throttle is not open.
Untitled by alex.hughes.1991, on Flickr
EGR Delete done correctly?
Re: EGR Delete done correctly?
Mot sure what the micro switch thing is.. but EGR plank plate is fine..
same as i did on our audi, skud, my mk2.. celica..
Also make sure the pipe from the circle thing (i never remember th name) to the EGR valve 9pipe is no longer there in you pic) is blocked off other wise you'll have a vac leak.. but guessing who ever done it seems to have done it right so doub't youd have a problem..
as for micro switch.. no idea
doesn't have a ECU aftermarket extra in the boot at all that this sends a signal too? like a Dansik chip or somehting?
Cheers man, I'l have a look around it tomorrow. I don't think it has any aftermarket ECU or chips but you never know!
Nitrous WOT micro switch?
mr2garageswindon wrote:Nitrous WOT micro switch?
Haha I thought exactly the same mate! Can't think why we're thinking along that wave length.....
