I have been doing a lot of searching and reading around so feel I am quite clued up on common issues, I am aware this error has been covered many times!
I bought my first MR2 two weeks ago and unfortunately towards the end of the test drive it started hesitating and threw the error 52 knock sensor code.
I bought a new pattern knock sensor with some other bits as above from TCB parts
At this point the engine light would not come on straight away, I would get a minute or so of full power then engine light and limp mode.
I started going through possible issues so replaced the dissy cap, rotor arm
From reading around I thought that the issue may be using a pattern knock sensor, so took a deep breath and ordered a genuine knock sensor from TCB.
Reading through many forums regarding the error 52 one user suggested getting a new sensor and connecting it, not installing it in the engine just running a earth wire to the block instead to isolate the sensor so there is no way it could see any knock.
I am guessing this is showing the wiring is at fault.
I have just tested continuity on the wire now and it seems fine.
It's running standard boost.
I can't see any evidence of it running raised boost, all lines around the actuator look very old and original with no sign of clips being removed.
It was running worse before dissy cap and arm change so maybe that caused knock that killed the original sensor.
I am getting very frustrated with this now as running out of cash, and just want to drive it in this lovely weather!!
Any ideas?
