If engine didn't start
(relay click or less), then disconnect you battery and check voltage across terminals: should be 12.x volts.
If correct, reconnect car to battery and check again: if voltage drops right down, then you have a short somewhere.
Could be your starter motor solenoid has jammed.
Or one of the main relays is defective
/ major fuse has blown
Possibly even a short-circuit diode in the regulator
(alternator)?
I can't remember any of the relay locations, as I have not got a schematic
handy.
.but for so much NOT to work its going to be something near the front of the power circuitry,
the battery
/ charging
/ starting circuit: either a relay or fuse.
hth?
