High idle after removing part of inlet!?
caldridge7
Post by caldridge7 »
Hey guys,
Basically i decided to take of the part of the inlet to clean the four butterflys up and give it an overall clean and in the hope I could free up the butter flys vavles as they were solid...there was no luck but I put it back on and now when I start the car it goes straight up to 2000rpm - and then hunts at 2500rpm,
I bought a second hand part of that inlet with all the butterflys valves moving freely but still no change after fitting.
Need some mega advice if anyone knows.
P.S my car is a rev 2 uk model.
Driftlimits Performance
IMOC Affiliated Company
Re: High idle after removing part of inlet!?
As you're a technician this should be easy, clearly you have an air leak.
caldridge7
where all still learning haha, where do you think its coming from? gasket maybe? i mean theres only a vac pipe and a gasket... just dont understand why there would now be a air leak?
caldridge7
also i have just replaced the icv and the throttle postion sensor (second hand)
