Import Drivers door Micro-Switch
Darkzy433
Post by Darkzy433 »
Can anyone provide step by step.. pictures preferably.
Of the location and how to get to the micro switch in a import drivers door.
abovetherim
Re: Import Drivers door Micro-Switch
Post by abovetherim »
From memory once the door card is off you can get to the 2 little screws that attach it to the mechanism. Bear in mind this was a while ago son I can't be certain
Darkzy433
Post by Darkzy433 »
Is that for imports as the switch is in the actual catch mechanism isn't it?
mr2garageswindon
Post by mr2garageswindon »
Not the 2 door switches on the B pillar then?
abovetherim
As far as i can remember i just reached in with a little posi screwdriver as the 2 screws were visible..... but I may have had to;
detach actuator rod
undo 3 screws on the outside end of door
slide lock mech out
undo 2 little screws
unclip the wiring connector
mr2garages... No the 2 switches on the b pillar are the push button for interior lights and the lever for the seatbelt tensioner. Neither are associated with the central locking
