(rev2)
So running rich, rev on the drive and even in the low rev range can get some black smoke.
Also has that smell of fuel
(someone who followed said it had that smell when i put my foot down).
I've suspected for a while its running rich.
Lamba checked via diagnostics port and outputting like it should.
However I noticed the gasket between the exhaust manifold and the turbo is leaking, not loads but not a little bit either.
Could this make it run rich?
the other give away its running rich is the exhaust tip is black with soot.
Any tips from anyone?
