It was basically black and very greasy!
I purchased the recommended cleaning kit, the KN recharger kit.
One things for sure the
Only thing the kits good for is the re-oiling spray.
I cleaned it twice with this stuff and it still looked the same black it started out already.
So a quick google and I came across someone who used a cloths stain remover cleaner along with mixing it with soda water!!
This worked a treat! I gave it a couple of good soaks and you could see the old oil and a TON of grime float to the surface and heavier stuff sink to the bottom, AMAZING!!
Soda water, vanish cleaner and warm/hot water and a bit of soak time
I let it dry out for a day or so in the house, then a light spray with the oil.
from this
to this!
new oil on
