Get you OE brakes refurbed.
If you can do it yourself there are seal kits available
(I chose ones from biggred, they also do cylinders for the calipers if you need those to).
If you need someone to do it for you a competent mechanic should be able to do it but you could consider a full service like the one biggred offer, full strip down, coating of choice, new cylinders/seals.
the lot.
Now this is not as cheap as buying already refurbed like the ones off ebay but you can choose your finish!!
Also inspect and replace if necessary the slider pins and as already mentioned, DON'T USE COPPER GREASE.
On the sliders use red brake grease or the like.
I refurbed my own back in spring 2011 and the car gets intermittent use but the brakes have been faultless.
No one has mentioned this already but the addition of braided hoses can improve the feel of the brakes also.
Brand is up to you but be aware that only the Goodrich ones come with the same in built bracket on the rears.
Hel ones are just as good and have the correct fittings for the struts but don't have the in built bracket, but this can be overcome with a p clip!
