Just tried to start the car after putting the new engine in.
Got power so battery is good, can get light/wipers etc.
What should I be checking first? I didn't hear clicking from the relay but its raining so may have drowned it out
DottySkee wrote:I didn't hear clicking from the relay
2mad wrote:DottySkee wrote:I didn't hear clicking from the relay
Pull the large cable bolted to the starer and clean it up.
using a dremel or sand paper
had this happen to me loads of times
DottySkee wrote:Gah! Changed body loom on advice from said mechanic.Do you have the diagram for the re-pin in the footwell Peter? Probably the easiest job now rather than swapping the body loom back to the rev 2 and repinning at the ECU.
Peter Gidden - SBITS wrote:DottySkee wrote:Gah! Changed body loom on advice from said mechanic.Do you have the diagram for the re-pin in the footwell Peter? Probably the easiest job now rather than swapping the body loom back to the rev 2 and repinning at the ECU.
I do somewhere, but it's 10 years since i changed a body loom as part of a conversion.
Just use your Rev3 loom as a comparison and an ohmeter to work out which pins are different, and change accordingly.
DottySkee wrote:Peter Gidden - SBITS wrote:DottySkee wrote:Gah! Changed body loom on advice from said mechanic.Do you have the diagram for the re-pin in the footwell Peter? Probably the easiest job now rather than swapping the body loom back to the rev 2 and repinning at the ECU.
Gotcha, so just use the rev 2 loom out of the car to match up the rev 3 loom in the car at the footwell end, check on a meter and plug it in.I may come back with some questions though.
Thanks for the help
Thanks for the help
Using a continuity meter, check where each wire at footwell end of Rev3 loom goes.![]()
Compare with Rev2 loom, and repin as necessary.
Start by finding your earth problem.
