Hi guys,
As above whats the best paint to use to paint my hotpipe?
steve
[Mk2] [Turbo] Best paint for hotpipe
Re: [Mk2] [Turbo] Best paint for hotpipe
when I had a hotpipe, I painted it VHT black.
Yeah mine black at the moment but want a different colour, wasnt sure if people powder coated them?
Hi temp paint will do the job buddy
Ok cheers
Remind me- I'm guessing it ain't a good idea to use primer with VHT paint? You just use it on it's own don't you?
I just used VHT on its own
Has anyone used the hycote paint and lacquere?
You have to use hi temp paint on its own .. make sure the surface is clean and contaminant free and spray lots of cotes .. i thought it would be ok to use normal paint .. I failed ... after 3 months it bubbled up
The hycote paint and lacquere are both designed for vht
ashley wrote:Remind me- I'm guessing it ain't a good idea to use primer with VHT paint? You just use it on it's own don't you?
I have used it with no primer - when I paint the part I always heat it up in the oven first, paint it then bake it in the oven again - The joys of living in your own home on your own!
Thanks guys...I figured they'd do a VHT primer if you were supposed to use one!
I've got black powdercoated pipes and they seem to be ok until now
