![Image](http://i1092.photobucket.com/albums/i404/lazza1/Picture018.jpg)
![Image](http://i1092.photobucket.com/albums/i404/lazza1/newshell1.jpg)
![Image](http://i1092.photobucket.com/albums/i404/lazza1/2013-07-06133718.jpg)
![Image](http://i1092.photobucket.com/albums/i404/lazza1/LarryFinal-2.png)
![Image](http://i1092.photobucket.com/albums/i404/lazza1/422.jpg)
![Image](http://i1092.photobucket.com/albums/i404/lazza1/424.jpg)
![Image](http://i303.photobucket.com/albums/nn140/larry1993_photo/mr2%20build/Picture091.jpg)
![Image](http://i303.photobucket.com/albums/nn140/larry1993_photo/mr2%20build/Picture092.jpg)
![Image](http://i1092.photobucket.com/albums/i404/lazza1/DSC01257.jpg)
![Image](http://i1092.photobucket.com/albums/i404/lazza1/DSC01256.jpg)
![Image](http://i1092.photobucket.com/albums/i404/lazza1/afterpaint.jpg)
![Image](http://i1092.photobucket.com/albums/i404/lazza1/DSC01249.jpg)
![Image](http://i1092.photobucket.com/albums/i404/lazza1/nitidedcrank.jpg)
It has come the time with regret to sell beloved mr2 turbo
I have owned this car for 8 years and spent a lot of love and attention on her and spared no expense, please visit my garage for more pics
The car has gone through a lot of transitions during that time the final build took place in mid 2010 when I went for a total engine new engine build due to previous engine having failed crank bearings
I decided on the 2.2 camry block build and sourced all the parts required and at the same time had turbo and waste gate refurbished by turbo dynamics.
Specs are as follows
Camry 2.2 block acid dipped and 3s crank with new arps
Acl race bearings
Hks conrods
Hks pulleys
Hks 280 and 286 cams
JE 87.25 pistons forged
New oil pump
All the valves were replaced
New oil squirters
Aftermarket exhaust manifold
3 bar map sensor
Denso 850 cc injectors and walbro fuel pump
Hks 3074 turbo turbo rebuilt same time as new engine and hks 50mm wastegate
Jetex marge air filter
front and rear polybushed mount
The full build was done buy a second to none builder well known throughout mr2 scene with a very good reputation I have a full cd of pics of complete build
The gearbox was totally refurbished at the same time and 1.5 diff installed.
Kakimato s/s single exit 3.5 straight through exhaust
I have used a radtech charge cooler system which has 2 x bosch pumps installed
The clutch is an OS gilken twin plate clutch with braided slave hose
Crw drive shafts for extra strength for the power new slave cylinder fitted
The ecu is an apexi fc with commander and boost controller is also apexi.
The suspension is Ohlins adjustable dampers and has white line arbs front and rears and adjustable pillowball drop links all round
Braided brake lines and front carbotech
Oil temp oil pressure and water temp gauges all installed.
The car was mapped by Ryan at 2 bar tuning on a hub dyno.
The interior has red mk3 seats
Spax front and rear strut braces
The body has race design kit bumper
Wheels are enkei rp01s 16 7s on front 8s on rear with Goodyear f1s 205 on front and brand new toyo t1s 225 rear
Its is fitted with a toad alarm system and battery is new 4 weeks ago.
The car has fresh mot till Aug 2015 no advisories
I had both rear sills cut out and replaced and undersealed and both rear arches were again cut out and replaced
The mileage is 84000 km and has done 4000km since rebuild
This is an extremely fast car and not for feint hearted it will do
I do drive this car daily and with boost controller set at 1.1 bar is very drivable.
I would hate to count the cost of this build but cant be far off 20k I dont expect to get that money back but for the pleasure ive had its worth every penny
if you wanted more power out of it could be done just upgrade injectors to 1000cc and go for boot mount intercooler and reckon you could hit 600hp-650hp not a great deal of expense involved
THERE
AND FULL SPECS IN MY GARAGE
LOOKING FOR
i will not let anyone test drive this car but happy to take you out in it
