Have been using castrol magnatec 10w/40 in my rev 3 turbo but at tesco they are selling it half price
Before I go and snap a load up, is it considered a poor
Odin_S wrote:Well if it helps I use Mobil 1 10w-40 and have been using since I got my turbo in'08.
I do change my oil every 4 months though.
I prefer to change my oil more than keep full synthetic and keep it for a year.
I am however getting my car back after an engine forged rebuild, so unsure on a higher powered engine.
jimGTS wrote:Odin_S wrote:Well if it helps I use Mobil 1 10w-40 and have been using since I got my turbo in'08.
You probably already know.Be sure it gets running in oil
(for beddings engine in) and no ya mobile 1 stuff until later!
Martin F wrote:You should be using a fully synthetic oil, magnatec is part synth.![]()
Odin_S wrote:jimGTS wrote:Odin_S wrote:Well if it helps I use Mobil 1 10w-40 and have been using since I got my turbo in'08.
How long must I bed the engine? 1000 miles? Luke is running in the engine before giving it to me.
Everyone has their own thoughts on running in.
If new rings have been fitted they need to bed in with the freshly honed bores.
So ordinary mineral oil only- no synthetic, semi-synthetic etc.
Drive it normally, using plenty of boost but limit revs to 5000rpm.![]()
Don't cruise at same rpm and don't use engine for braking.
Then change oil for synthetic and filer aty 500 miles.
Peter Gidden - SBITS wrote:don't use engine for braking.
