neilchan1981 wrote:Hi can anyone please help.I have recently bought an mr2 rev1 turbo which has had an uprated intercooler manual boost controller and hks fuel cut defender fitted.
Everything was running fine untill yesterday when i seemed to loose boost.
It has subsequently got worse today and it seems to pop under full boost and then i cant boost atall.
is this fuel cut.
I also noticed the cover from the stock bov seems to keep popping off have done temporary fix to this but has made no difference.
pls help.
It also has a decat fitted.
I have also noticed that the boost guage in the dash will creep up when not on boost.
But i have a aftermarket guage fitted and this does not move.
very strange.
is this fuel cut.
pls help.
very strange.
neilchan1981 wrote:neilchan1981 wrote:Hi can anyone please help.I have recently bought an mr2 rev1 turbo which has had an uprated intercooler manual boost controller and hks fuel cut defender fitted.
is this fuel cut.
pls help.
very strange.
Will check for error codes shortly.Now i have turned down the boost the after market boost guage is reading about 8psi.
cant see anything obviouse with pipework but will get it smoked checked on tuesday.
neilchan1981 wrote:neilchan1981 wrote:neilchan1981 wrote:Hi can anyone please help.I have recently bought an mr2 rev1 turbo which has had an uprated intercooler manual boost controller and hks fuel cut defender fitted.
is this fuel cut.
pls help.
very strange.
Will check for error codes shortly.Now i have turned down the boost the after market boost gauge is reading about 8psi.
Have checked for error codes and im getting 34 and 35.Excessive turbo pressure and open circuit for pressure sensor circuit.
The hks fuel cut defender is wired to map sensor could this be the problem
is this fuel cut.
pls help.
very strange.
I have also noticed that if ignition is on and engine not running the boost gauge on the dashboard is on maximum.Any help would be appreciated.
neilchan1981 wrote:fault codes are saying open circuit in boost pressure sensor circuit.
neilchan1981 wrote:sorry about that new to this lark wasnt shore i was doing doing it correctly
