[Mk2] [Turbo] Minor engine rattle....
2tmike
Post by 2tmike »
On a rev3 turbo. If you gently blip the revs from 1000 to about 1500 then as the revs die back there is a slight 'tappety' rattle from the rocker cover/inlet manifold area. Any ideas?
ashley
Re: [Mk2] [Turbo] Minor engine rattle....
Post by ashley »
Worn cam buckets? Pull the cover off and measure clearances, and inspect the buckets.
Sounds strange I know- but could be an exhaust leak maybe? EDIT- you said inlet side, so unlikely!
Peter Gidden
Post by Peter Gidden »
ashley wrote:Worn cam buckets? Pull the cover off and measure clearances, and inspect the buckets.
+1
2tmike
rattle
Post by 2tmike »
I guess so,,;((
I was half hoping there might be something in the inlet like the rev 1 t-vis
ashley
Post by ashley »
Well there is ACIS
2tmike
rattle
Post by 2tmike »
Has that got valves/flaps that could make a rattle?
ashley
Post by ashley »
It has valves, but never seen them rattle before...easy to check, unbolt the top half of the inlet manifold and have a look.
My money's on the top end though :thumleft:
EDIT: I'm talking b0ll0x...its the NA that has ACIS, you've got a turbo haven't you ](*,) ](*,)
Peter Gidden
ashley wrote:Well there is ACIS
Would you like to phone a friend?
2tmike
rattle
Post by 2tmike »
Just looked it up.....don't know if these ever do rattle but that's where the noise is loudest.
ashley
Post by ashley »
:lol:
nickromano
Post by nickromano »
I have a rattle in the same rev range..
maybe yours looks like mine ?
could you check here ?
http://www.youtube.com/watch?v=PEcMBJJLtOI
dan mkii
Post by dan mkii »
Iv heard this on a few rev3s ive checked the valve clearences and all checked out fine.
Just left it it hasnt got any worse but would like to know what it is .
2tmike
Noise
Post by 2tmike »
The top end sounds pretty much the same as mine. I did check all valve clearances and they were in spec, admittedly towards the allowable max in most cases.
Some of the noise on mine was an exhaust blow as an earlier reply suggested and having fixed that it just sounds like noisy tappets
nitrodave
Post by nitrodave »
could be the start of turbo-exhaust gaskets going
nickromano
2tmike I did not understand, have you solved the issue on your car or just left the noisy tappets there?
In my case I had the engine rebuilt, together with the head, so the exhaust gaskets were new.
I checked the valve clearance many time too and all was in spec.
That noise looks like a mistery to me
2tmike
Noise
Post by 2tmike »
Not really solved so going to live with it for a while as everything I look at checks out ok now. I'm running a 5/50 Motorsport oil and maybe a different spec or oil additive might quieten it down, but apart from that I'm out of ideas!!!
This is on an st205 celica and if I run the rev5 mr2 turbo (same spec engine) and compare, the celica is noticeably more noisy[/quote]
rs007
Post by rs007 »
This symptom has occured in the past, and its been the support bearing that is on the long drive shaft. Sounds mad i know, but mines had it. It can either be worn, or the little rubber tipped screw that helps secure it can lose its tip.
It rattles in that rev range in neutral, and its basically right under the inlet manifold, and has an almost "top endy" sound to it.
Obviously it could be other things, but I'd check that area out, no harm done.
nickromano
I'll check it asap.. I always thought it was loud from the bottom. Thanks!
nickromano
I did a little check on the support bearing and nothing seems wrong with it.. Also I couldn't find any rubber tipped screw on it..
However I put one end of a screwdriver on my ear and one on the oil pan and searched for the noise.
It is loader when I put the other end on the left side of the oil pan (looking the car from the back).
Could be a faulty internal bearing ?
