Powder coating rocker cover 3SGTE?
User avatar
Scott Barton
Post by Scott Barton »
The years have taken its toll on the paintwork on the top of the engine, especially when it was left to fester by the chap who bought the car and owned if for two & half years before i bought it back! Its started to flake, and lets the engine bay down.
I want to bring it back to its former glory, so would like to look at getting the paint restored or powder coated.
Need to get it back to this!
Anyone recommend anywhere?
al/c
powder coating
Post by al/c »
i would not powder coat it scott as they have to shot blast it first, 2k paint is the way to go :thumleft: ...ps i,m in the blasting industryso know the problems it can lead to.
Draven
Re: powder coating
Post by Draven »
al/c wrote:i would not powder coat it scott as they have to shot blast it first, 2k paint is the way to go :thumleft: ...ps i,m in the blasting industryso know the problems it can lead to.
See if was thinking about getting this done.. what would the issue with having it bead blasted first? As long as you get all the beads out..
User avatar
Scott Barton
Re: powder coating
Sound advice, cheers.
Stoopid question probably..what is 2k paint? 8-[
User avatar
Scott Barton
Re: Powder coating rocker cover 3SGTE?
Draven
Post by Draven »
Scott Barton wrote:This stuff?
http://www.ebay.co.uk/bhp/2k-paint
Erm yeah.. 2k is dangerous.. have to use it it with full breathing aparatus
User avatar
Scott Barton
Hmm...thinking its easy enough to remove the cover, so what thoughts on high temp spray paint?
Nails
Post by Nails »
Normal paint is fine. Ive had good results with hammerite smooth spray paint in the past. Easy to apply no primer needed and quite a hard finish
User avatar
Scott Barton
Had not thought of that. I have used Hammerite smooth in the past on my 205 GTI rear beam. Sprayed it Yellow and it came up a treat, and still looks great now. Could be the way to go!
Before
After, rebuilt with new bearings etc
Slarty
Re: powder coating
Post by Slarty »
Sorry, but that's complete nonsense.
I had my old rocker cover powder coated and it was NOT shot blasted beforehand.
I cleaned it up, granted it took a couple of hours of wire brushing and degreasing but it most certainly wasn't shot blasted. To that end, the first thing the guy in the powder coaters asked me was if I'd had it shot blasted.
The powder coating took fine and was still fine a couple of years after (when I broke the car) so as long as you're willing to put in some work, powder coating is fine.
Edit: Sorry Scott, that doesn't entirely answer your question lol. I used a powder coaters that's very local to me, so not really feasible for you.
juliankv73
Post by juliankv73 »
I had my rocker cover powder coated by a powder coater in Leeds
No probs and looks great!
fred130111
Post by fred130111 »
My rocker cover was done with rattle cans with normal paint!
I am aware this isnt the way to go but its lasted over a year and still looks like new :)
User avatar
Scott Barton
fred130111 wrote:My rocker cover was done with rattle cans with normal paint!
Got any pics? Keen to see some finished results before I either give this a go myself or pack it off to some powder coater somewhere. :thumleft:
fred130111
Yeah dude I'll get some tomorrow! I did some research and people all said if your doing it yourself use "very high temperature" paint but I had done that on the inlet manifold and the finish wasn't great, so I thought to hell with it I'll give it a go on the rocker cover with normal paint, just used Halfords white primer and then white paint and lacquer, it's shinny and hasn't cracked and that's all that matters to me :)
And I did rush it, I didn't bother with Degreasent just some sand paper and kept cleaning it with hot water and drying, so if someone was to do more of a proper job and took their time I have confidence that the results would be brilliant, ah I will add that when I put it back on and let the car run whilst checking for oil leaks etc it did get a bit sticky but that's probably because I didn't bother to leave it for as long as I should of but it was fine the following day and has been since!
User avatar
Scott Barton
Well i opted for the powder coating in the end.
Found a local company with a cool name.. 'Big Dog'... :lol:
Its with them now so hopefully it will turn out OK. He did say to me that there is a risk of any residual oil on he surface reacting with coating but will shot blast and de-grease as far as he can prior to the work.
Cross fingers.
l1ca
Post by l1ca »
Get some pics up when its done! :)
Peter Gidden
Post by Peter Gidden »
Scott Barton wrote:but will shot blast.
Hope he is able to remove every single grain that gets under the splash plates inside the cover.
nitrodave
Post by nitrodave »
i would not recommend powder coating rocker covers.
No matter how hard you try, you will not get rid of all the shot blast which gets mixed in with the engine oil and wrecks engines. I've seen it happen too many times.
Just spray it, you don't even need VHT paint as the temps don't get too hot up there.
Draven
Post by Draven »
I'm just rubbing down time and am going to spray it. Not worth getting anything under there in the engine. With plenty of prep and masking you can get a good job painting. :thumleft:
bobhatton
Post by bobhatton »
I can see an engine build coming up
