It's pretty straightforward although actually getting the camcovers off can be a bit tricky if you haven't done it before.
Once you've undone the chrome dome nuts you'll find that the rubberised washer things will probably be quite well stuck in place due to a combination of age and exposure to heat.
The covers won't lift off until you got those off, I usually use a screwdriver to lift the washers a little then unwind them off the thread by hand.
Then once they're all off the cover will probably still be stuck.
A tap on the side with a rubber mallet should knock them loose though.
