The only modifications are Exhaust and Decat and A Pipercross airfilter
I apologize in advance for my lack of knowledge, anyway I bought the car around 2 years ago and recently had a dyno and it came out at 149BHP now from what I understand they were born with 156.
At around 100K the engine was rebuilt but since then nothing has been done
there are a few things that i am aware need to be done such as rocker cover gasket as it seems to be leaking oil when giving it a bit of oomph and the clutch also slips on hard launches this was not done since 110K, oh and the cambelt was done at 100k but no signs of it needing to be replaced however i will do this anyway
anyway cut the story short i am thinking of taking the engine out and literally rebuilding so that its basically a brand new engine
my main question is it worth the effort of doing this or shall would you advise that its probably best just to replace the clutch, cambelt and rocker cover gasket?
Ah and one last thing the exhaust is blowing from the flexi pipe so i can imagine it may be losing a little power as a result of this?
Any ideas or opinions are appriciated
Thanks!!
