You won't go wrong with CP, Wossner or Wiseco pistons- you need to shop based on what compression ratio you are after, and that means you'll probably end up with CP or Wossner- both excellent makes of piston.
For rods it depends on what kind of level of assurance and performance you are after, and it is not all about power levels- how hard you plan to rev you engine plays a key part in how strong you want to go.
The stock rods are forged, and people make really good power with them- but by design they are not the strongest solution.
Eagle rods are a fantastic budget option, they don't cost the earth and are plenty strong enough
(you will be told by other members on here that they are cheap and nasty Chinese tat, but you only need to look at some of the after market tuners that use them, and the results they get, to see that they are by no means poor quality).
Then you have the higher end rods made by the likes of Carrillo, etc.
Much more expensive, but you pay for what you get.
If you aren't in a huge rush I have a set of Eagle rods for sale in the next few weeks
(as soon as Peter strips them out of my engine), they've covered less than 5,000 miles and have not rev'd past 7k rpm.
I'm sure Peter would be happy to inspect them for you, and you can have them for a decent price if you are prepared to wait
