Speakers
Speakers
Looking to upgrade the mr2 mk1 speakers any thing I should look out for? Sizes etc the standard ones sound tinny and one rear one blown.
Re: Speakers
Hi
superRedmr2 on here is selling a system give him a pm
kev
kev
Speakers
There were good Alpine ones in the front of my car when I bought it and I've tried 2 other sets and they all sounded a bit tinny, even with acoustic wadding packed behind them.
In the end I built a speaker box to replace the centre console and disconnected the little rear speakers. There are a pair of good qulaity speakers in my box run off their own amp and they sound good.
I still have the front speakers connected and might take another look at door mounting them some way.
It's an 80s car and unfortunately 80s ICE was pretty basic.
- Lauren
- IMOC Committee
Re: Speakers
3" rear speakers are just not big enough really to be any good. The story with the fronts is not much better.
But, maybe you could look at a 2 way coaxial in the front, but again 4" isn't really big enough. Guess you could spend decent money and see what you can get result wise.
I wouldn't bother with the rear ones, I would look at a slimline sub. It'll cost you but it'll be the only way to get some depth without trying to ask too much of the front speakers. You can then run a 3 channel amp and do it that way.
It might prove worthwhile to go to a decent audio shop and get some advice on what may be able to fit and your options.
I had a pro-install done on my GT86 though I could have much bigger front speakers at 165mm. I also had a sub put in the boot along with amp and a digital sound processor to alter the timing of the speakers and the balance of the sound. You could run a high pass filter (any decent head unit will do this) to let the sub do the work.
The MK1 is a bit of a nightmare to be fair to get any kind of decent sound as there's not much space anywhere.
2020 GR Yaris - Circuit Pack
