Coil overs & ARB
Coil overs & ARB
Anyone recommend some cheep as chips coil overs for my Mr-T and a good ARB or best to weld to stand ones together?
Re: Coil overs & ARB
sherwin1983 wrote:cheep as chips
sherwin1983 wrote:coil overs
I've never seen the two phrases used together.
Bottom end of the market will reward you with nothing more than the usual paddy field quality and longterm reliability.
LOL
@ welding two standard anti roll bars together!
Seriously? I don't mean to mock but that made my morning
- Lauren
- IMOC Committee
Buy some 2nd hand konis and springs off someone.
Shelve the idea of cheap coilovers it will be a disaster.
Cheap coilovers are still not that
'cheap' anyway.
2020 GR Yaris
- Circuit Pack
sherwin1983 wrote:Anyone recommend some cheep as chips coil overs for my Mr-T and a good ARB or best to weld to stand ones together?
I have two front ARBs on my GT6, connected together with short arms
Waiting for PW comment.
Not very lightweight is it?
platmatt8 wrote:Lauren has got bigger balls than most men on this site
charged wrote:Mine's probably screaming'stop raping me'
pk_090 wrote:Not very lightweight is it?
A GT6 is certainly not lightweight
You can fit an 18mm roll bar off a mk2 for an upgrade.
I think someone on here has used coilovers from an mx5, but even then fab work was required for them to fit and they weren't cheap.
If you want to buy new suspension for your mk1 dont buy cheap stuff.
How much were you looking to spend?
EDITED BY ADMIN:
You need to be a premium member to sell on here.
EDITED BY ADMIN:
Lol you need to be a premium member to even suggest you have some parts too! Lol
SuperRedMR2 wrote:You can fit an 18mm roll bar off a mk2 for an upgrade.
Sam
Paul Woods originally invented the conversion
http://japshop.co.uk/acatalog/TOYOTA-D2 ... -SHOP.html
Not sure if those are any good but they are under a grand so make of that what you will.
Red Wedge wrote:http://japshop.co.uk/acatalog/TOYOTA-D2 ... -SHOP.html
Under
BC coilovers are well thought of but
I'd have the BC coilovers any day of the week if I didn't have my koni's
I did a bit of research on those D2s and there have been mostly good reviews from Civic, Evo and WRX forums.
Jury is still out on the whole but they seem like a growing brand that are cheap at the moment but only because they don't have much of a reputation.
I might get a set myself as my standard suspension is knackered and replacing it would cost roughly
£400, seems silly to not hold out a bit longer and go for coilovers if I can afford it.
D2 is the same bull.
as K Sport: Cheap China stuff.
Always the same dampers for every car, brake line brackets You´ll have to fabricate out of universal parts and often fitting problems.
The brake kits are even more worse.
I don't know, they have a growing reputation in Australia apparently and all the reviews on the various owners forums I've found have been pretty much all positive.
They also
(apparently) manufacture everything themselves, including springs.
Shame there's no reviews from a more reputable source like a car mag or similar.
They also
