Also even in the states where the voice commands ar designed to work you cannot use the hdmi pass-through port along with the optical out (as we have had to do in recent years for the Sky hd boxes)
Appreciate your comments regarding the cars in F5 and YOU may only use 30 cars or so but how do you feel about the track list being only 14????
As for the quality of cars in GT6 don't forget that's last generation and a ps3 is available for £150(ish)
Appreciate that micro-transactions are going to play a big part of the future of gaming but when the game is £45 I expect a finished game not a game I need to spend another £45 to get the full experience of!
Ekona wrote:From Albert Panello:
This is unrelated to the HDMI-IN Surround Sound beta. To clarify, we default HDMI-IN audio to be converted to Stereo. However, we do have a feature you can access in TV settings/Troubleshooting that enables Surround Sound in beta form. If you check the box, and you get Surround, youre golden. We found some inconsistencies in STBs during testing and decided to disable it by default to insure a good initial setup experience for people.
So there is HDMI surround pass through, you just need to enable it.
Well at least that's good news but still begs the question why is it in beta when it's integral to a home entertainment setup??
until the bugs are ironed out and the kinect works like Ms would have you believe it does and you can use your sky hd box as MS have shown you can (with cable boxes in the states) then I'll just be sending my output to my av amp.
Also given the fact that some 8 years after the 360 was released MS still couldn't fix the DD bug that was present then I'm not holding my breath for this to corrected
