Service parts
Service parts
Need some advice please. The rocker cover gasket, dizzy cap and rotor arm and all the main service items are they all the same as want to order a load of service parts for my rev 2 turbo but not sure if n/a are the same.
Re: Service parts
the bear1986 wrote:Need some advice please. The rocker cover gasket, dizzy cap and rotor arm and all the main service items are they all the same as want to order a load of service parts for my rev 2 turbo but not sure if n/a are the same.
Some parts are the same others parts are engine/Rev specific, the best thing to do would be to give the Toyota dealer your model, engine and frame number from VIN plate and they'll be able to identify the correct part numbers for your car.
Re: Service parts
Ok thanks for the info. Would u know if the dizzy cap and rotor arm are the same for the turbo and NA?
Re: Service parts
Can anyone shed light on these for me please?
Re: Service parts
Have you been to Toyota and asked them ?
Have you looked it up yourself on a site such as cam skill ?
Have you called any of the specialists or specialist parts suppliers, such as rogue, tcb, fensport, motex, euro car parts, part co etc ?
I'm more than happy to help most people, but a simple bit of leg work would give you your answers, and not have you sitting here waiting for 'some guy on the internet told me it would fit'
Re: Service parts
I did go to euro parts and mr t and asks them both if these would fit and both said they wernt sure so that's why I'm asking on here for some advice. As both places said they don't deal with imports so couldn't confirm. So yes I've done the leg work but have not got the answer I needed. Thought this was a forum for users and advice!!!!!
Re: Service parts
It is indeed a place for advice, and if you'd stated that you'd already tried a couple of avenues, it wouldn't have looked like you were just being lazy
I wasn't having a pop above, but it came across as though you hadn't done any research yourself. MrT orders parts using a chassis and frame number, so they would easily be able to order the correct part. If you don't give them those details, they will blag it and just shrug their shoulders !
The best place I've found for service items, is camskill. Their site is dead easy to use, and they're very cheap
Re: Service parts
You could contact Chris at GTSChris who will be able to supply what you need. I've used Chris for a number of parts and always had very good service.
http://www.gtschris.com/store/comersus_index.asp
Some other UK trader links that may help.
http://www.fensport.co.uk/Parts.aspx
http://xxxx/catalog/
http://www.tcbparts.co.uk/
http://www.mr2-ben.co.uk/categories/view/sale-items
http://www.dcperformance.co.uk/performa ... a/mr2.html
http://www.garagewhifbitz.co.uk/index.p ... a/mr2.html
http://www.roguesystems.co.uk/forms/products.aspx
http://www.camskill.co.uk/
These are the Toyota part numbers for a Rev2 Turbo distributor, if you need any other part numbers just let me know and I'll look them up on the EPC.
Re: Service parts
Thank you very much for your help. Could you find the part number for the rocker gasket and rotor arm please.
Re: Service parts
check out mr2ben - v good for service bits
