Brake banjo bolt washers
going to have to remove the banjo bolt on the rear calipers to change my struts just wondered what size of crush washers do i require ...anty help appreciated W
Re: Brake banjo bolt washers
see i was thinking that ...im replacing the 2 rear coilovers on my tubby back to black billies ...on the coilovers the flexi hose is just cable tied to the strut body...would it be ok to do the same with the billies its for the MOT?...cheers fro the reply W
yes they will but but if i have to cut and bend them down to save me from disconnecting brake hose ...hmmm i shall see
You then bend them back up and slide the u clips in to hold them in place
I cut a slot in each of mine so I didn't have to bend the bracket, and as above the u clips should keep the hoses in place.
The washers are not 'crush-washers' They are simply copper washers. They can be re-used without problem despite what you may have read.
The washers will harden over time and when re-using it is wise to anneal them with a blow torch after which they will regain their original flexibility.
madbasshunter wrote:Just cut a slit in the bracket on the strut and bend down one side so you can remove the brake hose without undoing it
I have yet to understand why anyone that has any respect for their car and the individual components fitted to it would ever consider hacking at their struts just to save a couple of minutes of bleeding.
Peter Gidden - SBITS wrote:madbasshunter wrote:Just cut a slit in the bracket on the strut and bend down one side so you can remove the brake hose without undoing it
+1
+3
And the copper washers are crush washers, they're made of copper and squash when you tighten onto them: that's the whole point! When it comes to brakes why take a chance? They literally cost pennies to replace...do it properly
+4
Brakes probably need bleeding anyway.
