help starter motor wont switch off!
Any one got an idea of what would cause this?
Re: help starter motor wont switch off!
Dodgy relay perhaps?
What I thought so swapped relay around but no luck with that but I have fixed it!
Found my special starter motor repair tool
Have you been doing any work on the engine?
If so check the eathing strap under the inlet manifold, sounds like it is not fitted
Yes and I had already checked all of the engine earths. Im putting it down to not being run for 6 weeks and the freezing temperatures recently.
