It depends on alot of factors, but your correct in saying tyre profile is one of the primary factors.
Poor quality and
/ or overly stiff springs plus poorly match
/ valved dampers
(TBH most aftermarket kits are) will ruin ride quality and suspension performance as much as a change to lower profile tyres.
17" wheels tend to be heavier than 15
/ 16" wheels, which again compromised damper performance.
If you get a set of proper lightweight 17" wheels, and stay sensible with the profiles
(45 is optimum, 40 is the limit, 35 is just too low IMO) then there's no reason they cannot perform just as well as a 15" wheel
(given similar overall circumference).
I do agree 16" wheels are about the optimum for a road use car, as they tend to be available in staggered sizes, are as light as the standard wheels in many cases.
If you are running
~300bhp
/ 300 lb/ft then a wider rear tyre is beneficial for traction in most circumstances, and unfortunately many 16" wheels can only take up to a 245-section tyre
(from a limited number of manufacturers).
Depends what you using the car for.
For me, if I end up with another high power MR2, I'll be trying for a 16" front
(215/45/16 or 225/45/16) and a 17" rear
(255/40/17) which I think will provide a good balance between grip, compliance and unsprung weight.
