[Mk2] [NA] central locking
dadio
Post by dadio »
hi guys ,im a newby ist time on here,hope you can help me please ,ive gotcentral locking problems,both doors lock / unlockfrom the drivers door internal switch but the passenger door will only unlock from the drivers door key lock it wont lock , im puzzld got the door cards off as its dry stored at the moment but want to fix it thanks hope someone can help me
Peter Gidden
Re: [Mk2] [NA] central locking
Post by Peter Gidden »
Use a 'scope to check for lock and unlock pulses in the wires. If OK, then likely door solenoid has failed.
dadio
Post by dadio »
ok i will try thank you
Return to “Electrical”
