Hi all
I have an issue with my AW11 which is very difficult to start.
The battery seems ok and is turning the engine over well enough, but it is not really even attempting to fire now.
I did charge the battery at the weekend just in case and it started at the absolute first turn of the key
- but i had also cleaned up the rotor arm, dizzy cap, leads
(all of the parts were new 3000 miles ago), as well as cleaned all contacts that i could find including the earth cable from the engine to body but now there's nothing.
I suspected the damp may have been an issue but after cleaning everything it seems maybe not.
Any suggestions as to where to look? Do the coil ignitor packs generally cause issues? Any other suggestions?
