[Mk2] [Turbo] I want 450bhp, what do I need
will the stock valves, valve springs and crank etc handle 450bhp? realistically this is as far as I will push my car in the end and need to know what stock parts to upgrade... Fuel pump and turbo are obvious, as are intercooler and pistons but what else?
Re: [Mk2] [Turbo] I want 450bhp, what do I need
Alot of money.
Chris wrote:Alot of money.
^What he said. I'd set aside £5K
GT3076 Turbo kit
Stand alone ECU
Kevlar cam belt
Cams
Forged pistons
Forged rods
ARP studs
800cc injectors
Walboro fuel pump
3 bar map sensor
Cams
Decent charge cooler
Free flowing exhaust
Mapping
etc etc etc
- IMOC Affiliated Company
cheap
reliable
powerful
Pick 2!
reliable
powerful
Pick 2!
Skywalker wrote:cheap
reliable
powerful
Pick 2!
Exactly.
if its a rev 3 lump then stock valves and cams but the ports will need cleaning up.
rods are a good idea as well as a full set of ARP fastners.
then a turbo, injectors and ecu capable of running the power along with some form of charge cooling and possibly water/ meth injection
not looking at cheap, just gradual! will probably be a 10k car when I'm done!
dawesy wrote:if its a rev 3 lump then stock valves and cams but the ports will need cleaning up.
Thanks! will make a list.... will start with forged pistons and go from there!
reliable
powerful
Pick 2!
Epic post
bennyboi88 wrote:not looking at cheap, just gradual! will probably be a 10k car when I'm done!
You owe me a 10 second car.
Dom
RedMR² wrote:Chris wrote:Alot of money.
GT3076 Turbo kit
Stand alone ECU
Kevlar cam belt
Cams
Forged pistons
Forged rods
ARP studs
800cc injectors
Walboro fuel pump
3 bar map sensor
Cams
Mapping
etc etc etc
The one on the right then Alas only the one on the left is for sale though
reliable
powerful
Pick 2!
There is one for women as well.
Hot.
Great personality.
Emotionally stable.
Pick two.
bennyboi88 wrote:will the stock valves, valve springs and crank etc handle 450bhp? realistically this is as far as I will push my car in the end and need to know what stock parts to upgrade... Fuel pump and turbo are obvious, as are intercooler and pistons but what else?
Do not buy anything untill you have the full design of the engine as everything will need to work together.
Al-sw20 wrote:Skywalker wrote:cheap
reliable
powerful
Pick 2!
Hot.
Great personality.
Emotionally stable.
Pick two.
Magic Beans wrote:RedMR² wrote:Chris wrote:Alot of money.
GT3076 Turbo kit
Stand alone ECU
Kevlar cam belt
Cams
Forged pistons
Forged rods
ARP studs
800cc injectors
Walboro fuel pump
3 bar map sensor
Cams
Mapping
etc etc etc
That going in the '64 herald behind it?
reliable
powerful
Pick 2!
staright to the point, love it!
reliable
powerful
Pick 2!
Hot.
Great personality.
Emotionally stable.
Pick two.
Unfortunately they present as having all 3 initially,
with time you would be lucky to end up with 1!
