ive done a search and its not conclusive that i can see.
im about to possibly change the rack (may just be the arm)
but if it is the rack then ill change the fluid also obviously.
so the question, does it need to be special for electro systems, some posts ive seen suggest yes and others state any ps fluid.
if special, is it toyota only
power steering fluid
Re: power steering fluid
It should be electro-hydraulic fluid, not ordinary stuff.
Doesn't necessarily have to be from Toyota though.
Many have used EH fluid from Peugeot (for the 307).
I got mine from Toyota that way I new I couldn't go wrong.
JohnnyC wrote:It should be electro-hydraulic fluid, not ordinary stuff.
cheers
as above it should be electro hydraulic...but normal red hydraulic works fine..ive been using it for years with no issues....the system is essentially the same as any other system minus the fact that pump is powerd by electric rather than a belt.
EHPS fluid has a different viscosity to "normal" PAS fluid as electric motors don't like pumping thick oil.
That's why EHPS systems should use EHPS fluid.
all good to know, i wont be changing the rack now for a while anyway, turned out to be the ns track rod arm that had a little play so a nice simple fix
get form peugeot think its only there 307 that uses it. the fluid is a gold colour. halfords dont stock it and toyota charge alot
MR2O12 wrote:toyota charge a lot
£25 ish. Enough for 2 fills. Seems reasonable.
If anyone wants OEM fluid, enough for one fill, PM me, i'll ship what's needed.
I looked into the Peugeot ehps fluid and found a post saying that the specs of the Toyota and Peugeot fluid are quite different, I think I'll stick to oem just to stay on the safe side, besides a new power steering pump is ridonkulously expensive from Toyota.
Does anyone know of an easy way to drain the system?
Harold wrote:I looked into the Peugeot ehps fluid and found a post saying that the specs of the Toyota and Peugeot fluid are quite different, I think I'll stick to oem just to stay on the safe side, besides a new power steering pump is ridonkulously expensive from Toyota.
I'd be interested in this also, if end up keeping the car which it looks like then I'll be changing it for piece of minds sake
