Last weekend i replaced my rocker cover gasket as i had the usual leak in the bottom right of the engine where it drips onto the alternator.
After having already had one alternator blow i decided it was time to sort the mess.
Everything was done by the book, i made sure after the old gasket was taken off that it was cleaned meticulously so that there was no residue. I also made sure that i put a bead of gasket sealant in the corners to help seal things tight.
I used new hex head screws bought from Kelsport and made sure that they were all tightened evenly, working my way slowly round them doing a bit each time but also making sure they were not over tightened.
Everything was fine until this morning when there is a tell tale drip of oil on my drive. I looked in the engine bay and sure enough the leak is there again
I am not sure what i have done wrong and am resigned to the fact that the car will ALWAYS leak oil from this area. I suppose it is only a matter of time before i will be buying ANOTHER alternator to replace this one when it fries!
Unless of course anyone can point out what i have done wrong or if there is anything else i can do different to prevent this.
Rocker cover woes
Re: Rocker cover woes
Did you use a little bit of gasget sealant on the corner that drips? This is always recommended else it will leak like that.
Yep, did this.
Could the rocker cover be warped which is creating a gap?
How could i check this?
Chloke83 wrote:Yep, did this.
Anything is possible I guess but I can't say as I've heard of one warping personally. To check it you'll just need a largeish truly flat surface. Lay the cover on it and see if it "rocks" or go around the outside with a thinish (maybe 0.1mm) feeler gauge and see if it slips under anywhere.
Slarty wrote:Chloke83 wrote:Yep, did this.
Well i suppose i will be pulling the top of the engine apart again this weekend!!!!!
Edit due to numptiness
Definitely the rocker cover, small leak in the usual place below the bottom right bolt.
- IMOC Affiliated Company
Are you using the little rubber/metal washers?
The rubber and metal washers.
Anyone know why the alternator is where it is in the MR2 and not round the front like it is in the Celica? The Celica has a PAS pump round the back I think but still manages to get the Alternator and A/C pump in up front out of harms way.
