Oilpressure problems with Gen2 and 3 at high G´s
Toyspeed
Post by Toyspeed »
I´m new to the trackracing scen with MR2´s.
But is there a problem with high G´s and oilpressure with the MR2´s ?
And if so, How did you solve it?
Where is the biggest problem? Left, right turns, acceleration or when braking?
Rogue
Re: Oilpressure problems with Gen2 and 3 at high G´s
Post by Rogue »
There can be issues using semi slick tyres on revision 1 and 2 cars, and we don't use these for Motorsport without fitting a baffled sump (Moroso). The revision 3 engines have a two piece sump that doesn't seem to suffer from oil pickup issues.
Funnily enough I was out testing a customer's turbo race car at Mallory park for this very thing!
Toyspeed
Post by Toyspeed »
So the moroso sump is the way to go?
I read the info I could find about the moroso sump. But I found that there where more dragracingcars that used this sump?
greeny
Post by greeny »
Toyspeed wrote:So the moroso sump is the way to go?
Same forces/g's acting on it, just in different directions.
The morroso's a decent sump and not overly priced really.
I got mine from Summit racing IIRC, (some years ago now though!)
TOTB 2010 Rwd top speed, 1/4 and shootout winner.
10.7@142 on R888 street tyres, 10.3@134mph on slicks,
9's on slicks to come, with a clean full throttle pass! Goal of 0-150mph in a 1/4 of a mile....
Peterwolf
Post by Peterwolf »
The Moroso sump can be installed in Rev1/2 3S-GE?
Or only fits 3S-GTE?
greeny
Post by greeny »
Peterwolf wrote:The Moroso sump can be installed in Rev1/2 3S-GE?
Im 99% sure it can, IIrc the block/sumps are the same.
HurleyRacing
Post by HurleyRacing »
A winged moroso sump is good middle ground but if its a competition car and you really want to solve the problem as well as ensuring the engine peforms well a dry sump set up is what you need.
We recently have put a couple onto mr2s and have done our own bespoke soloutions for some of our formula 3 chassis customers using Toyota 3sges. I will try and post some pics up here soon
-Race Car Preperation -Engine Rebuilds
www.hurleyraceengineering.co.uk
[email protected]
bobhatton
Post by bobhatton »
Dry sump is the only way to go
