Oil in struts?
mulaz
Oil in struts?
Post by mulaz »
I am doing the DIY mx5 coilover mod
After stripping down the front struts and pulling out the shock inserts
i find that both legs had been filled with oil of one sort or the other (blue) along with the insert.
Both strut inserts are nearly new and not leaking.
did a google and find some people put some anti-freeze in before fitting the shocks??
any thoughts on refitting........ oil / dry / copper slip?
#-o
cartledge_uk
Re: Oil in struts?
Post by cartledge_uk »
I used the antifreeze method. :thumleft:
boondougal
Re: Oil in struts?
Post by boondougal »
The original units are not sealed like your replacements... I put a little bit of oil in the casing when I did mine but it only needed a thimble full iirc.
