3.
SHOULD I BALANCE MY NEW FLYWHEEL?
Since our product is CNC machined they are incredibly accurate.
We do however recommend that you balance your new flywheel along with your new clutch pressure plate.
This should be done by a reputable and competent machine shop.
I asked God for a bike, but I know God doesn't work that way.So I stole a bike and asked for forgiveness.
Jim-SR wrote:if you're not balancing the crank then theres no point in balancing the flywheel either.they should be balanced as an assembly and referenced to do it properly.
if the crank isn't balanced then a balanced flywheel isn't of any real benefit.
it will be close enough from Fidanza not to bother.
aw11rally wrote:Just sounding like a BDA would be good enough for me.
elbon50 wrote:As we all know the 4A-GE is a lovely willing& free reving little engine
I have been informed that when Yamaha designed it they made it as a very faithful copy of a Cosworth BDA
A very detuned copy though(for reliability)
Contrary to a false assumption that the 4A-G is a copy of the Cosworth BDA,(coincidental
A series designation on both engines).
There are little, if any, interchangeable parts between the two engines, outside of maybe some nuts and bolts.
The Cosworth 4-valve design started life using the Ford Cortina engine block, with its distributor located on the side of the block and progressed to belt driven Escort engines.
The basic block was, like the current formula Atlantic engine, based on a production block.
Most of the Ford blocks that Cosworth used could be taken up to 2 liters.
The 4A-G is limited to around 1.6 liters maximum, because of the deck height and bore spacing.
The included valve angles for the BDA is 40°, along with what has become a Ken Duckworth design feature, and that is the use of a separate camshaft tray.
To the contrary, the 4A-G has a one-piece head with the camshaft saddles cast right in.
The included valve for the 4A-G is 50°, more similar to the earlier Alfas or other Italian designs of the 70s.
A very detuned copy though(for reliability)Peter
