[All] [Generic] Enkei racing split rims refurbing
Baker
Post by Baker »
Has anyone any knowledge of splitting these rims?
Im hoping that its just a matter of removing the bolts and the middle will fall out without any gasket/sealing problems?
loudandproud205
IMOC Organiser
Re: [All] [Generic] Enkei racing split rims refurbing
Post by loudandproud205 »
Yup take the bolts out with 10mm spanner/socket on the back and a 10 sided either 8 or 10mm socket on the front.
Once they are all out you can just use a bit of force and they split leaving the outer lip and the tyre as one with the centre removed.
Just uploading a pic of mine split.
Got boost?
Kinda!!!
0.3 bar FTL
loudandproud205
IMOC Organiser
How they look at the min
Got boost?
Kinda!!!
0.3 bar FTL
Baker
Post by Baker »
Excellent, just the info i was after. Liking the colour scheme.
Think i'm gona go for black centres and keep the polished lip.
edit, found the socket info. can you confirm the mm size for me though please if possible?
thanks
loudandproud205
IMOC Organiser
8mm 12 sided socket for the front of them 10mm 6 sided for the rear
Front should be like this-
They are just standard sockets nothing fancy.
http://www.teng.co.uk/m120508-c-teng-to ... 836_pd.asp
I like the colour but I was hoping the bronze would be a little lighter so it may just change (again)
I was going to polish mine but I was wearing my fingers away quicker than I was getting anywhere with them, so decided a metallic bronze picked to complement the red against the (hopeful matte grey paint)
Got boost?
Kinda!!!
0.3 bar FTL
Slarty
Post by Slarty »
I was just going to say, make sure you use a 6 sided socket/spanner for the nuts :thumleft:
loudandproud205 wrote:10mm 6 sided for the rear
JeffD
Post by JeffD »
Have a read through my post of when I dod my work equips - might help :-)
http://www.imoc.co.uk/forums/viewtopic. ... it&start=0
Rahzel
Post by Rahzel »
Use a piece of wood and a rubber mallet when convincing the center to separate from the lips. Don't wont to bend it :-s
Enneaitch
Post by Enneaitch »
very cool post im doing somthing similar in the near future...
Marf
Post by Marf »
BUMP!
I just bought a set of these.
loudandproud205, how easily did the centres come out when you'd removed the bolts?
Looking at the backside of the wheel, I can't see a line between the edge of the centre and the inside of the rim, but I'm guessing they're just full of crap and I cannot see it. :-k
loudandproud205
IMOC Organiser
I used a rubber mallet to knock it through as it was tight.
Jumping on it made little difference and I started to think I couldn't split them but a few not over aggressive blows see it moving.
Remember to take it out as straight as possible.
Got boost?
Kinda!!!
0.3 bar FTL
Marf
Post by Marf »
I unbolted one of them yesterday and gave the inside a good cleaning out and found the line of sealant between the centre and the rim, and it is pretty tight eh! Rubber mallet it is then.
Cheers :)
