[Mk2] [Generic] Roof 'spoiler' removal
Hi, I need to take of the body colour trim piece that goes above and to each side of the back window (sometimes referred to as a spoiler). I can see a couple of screws each side below the engine inspection covers, but how is it attached to the roof itself ?
Re: [Mk2] [Generic] Roof 'spoiler' removal
Hi mike.
You need to rmove the roof interior parts aligned to the rear window
There I believe you see 4 or 6 nuts.. remove them
The lowest part of that "spoiler "is attached with click system..
Just gently pull it loose.
roof spoiler
Hi,
Thanks, I was hoping the headlining didn't need to come out .(((
Mike
Mike
Re: roof spoiler
2tmike wrote:Hi,
Mike
Nooooo Dont remove the headlining, just the hard plastic trim that butts upto the back window From memory you'll need a long 8mm socket to get to the nuts that hold the trim on.
Re: roof spoiler
2tmike wrote:Hi,
Mike
No mate
only the plastic thing.. aligned against rear window
Oops, I see already someone made that comment.
I thought a long 10mm was needed..
but don't pin me down on that ;P
The top trim is just clipped. Gently pull bit by bit, normally the clips won't snap.
I can't tell from memory if the top one can be pulled of before removing some other trim.
You might need to take of the side trim and rear quarter trim first before being able to get the top one of.
