[Mk2] [Turbo] Rev5 Tubby standard wheel-nut part number
Hello! Does anyone know that part number for a standard rev 5 front wheel-nut. They are about 37-38mm long in total. Thanks for the help in advance!!!! Ive searched and no one seems to have posted it before...
Re: [Mk2] [Turbo] Rev5 Tubby standard wheel-nut part number
if its the same ones that came of my rev1 (as you say quite long with a large diameter washer about 5mm from the wheel end) i got 20 of the things, will happily send you a few if you want
(ill pick the nicest ones - they are all used)
Slarty wrote:
it's just that we subscrible to the theory of hitting it harder until it works. Or something falls off, in which case you've hit it too hard.
Thanks for the offer - its very kind, but the rev 5 nuts are a different length from all the other revisions - the rev 1-2 are short...the rev 3 and 4 are very much longer...and the rev5 ones are the shortest!!..
Why-ever they didn't make them all the same size with the wheel inserts baffles me!!..
Bump as I need to order these!
Ask Toyota mate. They must be able to tell you this.
January 2014
May 2015
Still in the garage...
..the only thing I can promise for sure is slow progress.
May 2015
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.
pm sent. paul.
