I have to do this every now and then
- for no flipping reason the fob just forgets its purpose
(am I a tree? A sheep? What is my purpose in life? Why is this bloke throwing me on the ground?) and won't disable the alarm.
After trying the
'hold fob buttons down' trick so many times I never really figured out the sequence, just kept holding
& pressing buttons til the damm thing worked
- but I think I have the sequence nailed now.
Remove battery from fob
- this will clear any codes inside it.
Open car with key
- alarm will sound and you will look a tit
- not a lot you can do about that.
Put key in ignition and turn ignition to ON
- don't start the car.
Replace battery in fob.
Hold unlock button down until the light on the fob starts to strobe-3-4 seconds.
Hold down both buttons for 10 seconds.
You should now get a response when pressing the unlock button.
