Fail on following
parking brake efficiency below
front sidelight out
horn not working
rear tyre
exhaust emission fail
exhaust emissions lambda reading after 2nd fast idle outside specified limits
Ok so not too bad all in but i could do with some help on the parking brake and exhaust faults.
The exhaust is aftermarket and sounds like its straight through could this be causing the failure?
Also where is the adjustment on the handbrake?
Cheers folks
Marty
