I have had a look at the immobilisor.
The one that i have fitted is by laserline.
The model is laserline 936.
This unit is about 20 years old.
i think it was the original one fitted.
Anyways, i have found out that this unit is not an immobilisor at all.
Just a very basic alarm unit.
The starter motor relay has been tested and works fine.
Nothing wrong with that at all.
I am in the process of testing the starter motor.
Just need to find a suitable guide to read and then test my starter motor.
I have read else where that sometimes bad earthing can cause issues.
So later on i will be testing the earthing on the engine.
I dont think that the problem is worse than it sounds.
Just to recap on the history of my car.
The previous owner had taken the old original engine out
- the engine was an 3sge and replaced it with the 3sgte.
When i got the car it did start, the starter motor did work etc.
so the wiring is not faulty or damaged in anyway.
Oh well, better find the testing guide for the starter motor.
