Should i replace with another walbro or will the same thing happen, or should i replace with a toyota fuel pump?
Xmun7 wrote:Has anyone had this fuel pump fail in less than a year? on start up it pushes 6 bar which is good but then after a couple of seconds it only pushes 3bar.and pressure stays playing around never constant.
Hence the fuel pump has failed, we tested the regulator, fuel rail, checked filter all results in fuel pump failing.
