[Mk2] [Turbo] ECU light... please help
n426ams
Post by n426ams »
hi guys,
i have a rev 3 turbo which keeps showung my ecu light...
when it comes on the car runs lumpy and backfires under load...
if i switch the car off then on again the problem goes away...
then next time i drive it the same happens, i have tried to read the engine code but all im getting is a constant flashing, which i believe means all is ok....
please can someone help its driving me crazy :shock:
Mike
Re: [Mk2] [Turbo] ECU light... please help
Post by Mike »
Have you done anything to the car recently? Fitted an aftermarket part, raised the boost etc?
