[Mk2] [NA] radiator hose removal
pcfc
Post by pcfc »
Can someone tell me an easy way to remove the inlet and outlet hoses from my mk2 mr2 radiator please I've got the clips off but the hoses are very tight and awkward to remove? I have considered cutting them out and replacing.
JohnnyC
Re: [Mk2] [NA] radiator hose removal
Post by JohnnyC »
Pour boiling water over them, then dry them, then put some rubber gloves on, then don't just try to pull them off - twist them off :)
pcfc
Post by pcfc »
Thanks I'll give that a try sounds like good idea cheers
