I search about it but can't find a clear answer.
The Whiteline adjustable anti roll bars have 3 holes at the front and 2 holes at the rear.
At front should I use the outer, middle, or inner hole?
At the rear should I use the outer or the inner hole?
Or in other way to ask:
What setup did you use in your's ARB?
Cheers!
