Front Wheel Bearings
Is it possible to buy just wheel bearings for the front or do you have to buy the whole wheel bearing hub unit?
Re: Front Wheel Bearings
You can't change the bearing itself, its a complete unit - bearing, hub, abs sensor etc.
Part number 43550-17010 - about £200.
thanks,
i'm also getting a slight shuddering on braking. I was wondering if that could be something to do with a faulty abs sensor.
Thats one expensive part!
No it won't be anything to do with your ABS sensor.
Check disc runout for warping...
