Hi
Do these cars have a G-Force sensor fitted? If so where would it be?
My ABS light stays on and a diagnosis has given a fault code for a G-Force sensor. The garage does not know where this unit is and I did not think that these cars even had one!
You already posted this in the Mk3 forum and received a few replies but I dunno where that thread has gone.
I think Patrick from Rogue Motorsport responded by saying only Rev 4 & 5 cars have the decelerometer and it should be bolted to the top of the central tunnel, underneath the stereo and heater controls.
He said that it's a metal box with a yellow sticker on the top and people usually assume it's something to do with the airbags because of its position.
I think somebody else posted to say that a replacement from Toyota will be seriously expensive. *EDIT*
Found your other thread: http://www.imoc.co.uk/forums/viewtopic. ... highlight=
