Sooo.
How it used to be
So, we waited for the weather to be at its absolute worst, and we set off to work
We started fresh an early in the morning
at about 3am Viola!
and heres the damage.
So, my spec.
Re-conditioned block, decked, new oil squirter's.
Chrome-molly ductile cylinder sleeves
5SFE forged crankshaft 91mm stroke.
Omega 86.5mm forged pistons w/ceramic skirts and machined valve cut-outs.
Eagle con-rods
ARP Head stud kit
ARP Flywheel bolt kit
ARP Con-rod bolts
ARP Mains bolts
ACL Mains and small bearings
Toyota 1mm rev3 MLS head gasket
xxxx Magnetic sump plug
New OEM oil pump
Stock re-conditioned head with stock cams,valves and pulleys
Phoenix power
Nissan Q45 90mm throttle body
Nissan S13 200sx throttle position sensor
LinkPlus G3 XLEM engine management
Link 7bar map sensor
1200cc Bosch top feed injectors
ATS Top feed fuel rail, Dead headed setup.
Aeromotive 13101 FPR
Summit FP Gauge
Bosch 044 external 300lph pump
AN-8 goodridge fuel supply line
AN-6 goodridge fuel return line
Summit racing AN-8 inline fuel filter
Custom made fuel pickup
Custom oil heat exchanger replacement
Samco coolant silicone hose kit
Samco Aux silicone hose kit
2 spal engine lid fans on Gtech shroud.
Full Wire tuck
Modified Apexi Power intake
Blitz K1-380 turbocharger
Custom Boot mount intercooler with twin spal fans.
Custom Side vent blocking plates
Greddy Type-R BOV
De-cat 3" stainless downpipe
Custom 4" b-section
Phoenix power departure II Pro 3.75" exhaust
Os Giken Lightweight flywheel
Os Giken Twin plate unsprung motorsport clutch
TRD 1.5way LSD
Uprated shifter bushings
Tien Type Flex suspension
Cusco Type-II Rear strut brace
TRD ARB
Ant onions custom
Goodridge braided brake lines
Blitz Twin SBC-R dual solenoid boost controller
Greddy Turbo timer
Momo fighter steering wheel
Recaro SPD reclining bucket seats
TRS 4-Point FIA Aproved harnesses with custom mountings
TRD clock set
EMS powered digital boost gauge
Custom centre console with integrated 8" LCD touch screen
Mini-Itx pc with LinkPlus engine management USB link and software
Alpine CDA-9855r
PS2 slimline in car entertainment
Genuine Border racing front bumper
Genuine Veilside side skirts
Genuine Veilside rear bumper
Genuine Veilside rear spoiler
4xRear light
Custom engine lid gas strut
And a partridge in a pear tree!
Heres some pics of the progress.
X-member powdercoated
Mums worktop
Highly modified 5sfe Stroker crank
omega pistons w/ceramic sides
Eagle Rods.
short Block with powder-coated brackets
