dose any one know how many maps can be stored , switched between on the above ecu, ie- crap fuel , hot day ,economy for a long drive ,more or less boost .
i want to make sure im doing the right thing, turbo /v6
[Mk2] [Turbo] power fc
car now sold
most parts off gts chris
Re: [Mk2] [Turbo] power fc
just one on a PFC.
i thought you could swap between maps gutted
car now sold
i could be wrong now but can it be done with a laptop and an fc datalogit?
yes, then it can.
if you wanna run the PFC but want to run different boost levels then run a EBC and set the 2 different boost settings
The SW20 PFC has a boost controller built in that you can set to whatever boost level you want straight from the handcontroller. You can change maps but that requires laptop/fc datalogit to do so, it's not an 'in cabin' switch to flick.
However... You're running a V6 turbo? My understanding is that you would need to find a PFC that is expecting to run a 6 cylinder turbo. Maybe a Supra PFC or Nissan GTR PFC. This would introduce other problems like rewiring/changing TPS and other sensors (air flow meter etc) and would be a bit of a mission.
If you use a laptop and the software you can make as many maps as you like I guess.
