I'll start
350bhp
lets see who has got the highest!!!!
I was doing about a 60miles in her every day but I just got a new job so only 20 now!!! So I'm saving loads in petrol!!
Steve-O 2007 wrote:but are these Daily Drive"Winter MR2's" as well or are you tucking these beasts away for the winter??
Will be getting on a dyno soon once I get the AVCR fitted
Gee Man wrote:Steve-O 2007 wrote:but are these Daily Drive"Winter MR2's" as well or are you tucking these beasts away for the winter??
yeh mine is
440 is the ice/wet will be fun
I've still got r888's on as well!!!!![]()
yeh mine is
Gee Man wrote:As above really, what power is your mr2 kicking out as a daily drive??
I'll start
350bhp
Kongaroo wrote:
Power wise when I was still running myTD06
I had anywhere between 280whp and 350whp depending on what boost controller setting and whether I needed the extra power or not
I now have aGT28rs
which I consider a worse daily drive turbo on my car for reasons of boost creep
(and I have a 38mm external Tial wastegate too) which makes adjusting boost levels a pain
- was never a problem on the TD06.
Have yet to get back on the dyno with the new turbo though.
Kongaroo wrote:I'm still daily driving mine and have done over 4 years now![]()
Winter tyres were a godsend the last couple of years as we had quite a lot of snow fall and ice but I think the MR2 can certainly be daily driven all through the year if you are sensible and the car has the right tyres.
Power wise when I was still running my TD06 I had anywhere between 280whp and 350whp depending on what boost controller setting and whether I needed the extra power or not![]()
I now have a GT28rs which I consider a worse daily drive turbo on my car for reasons of boost creep(and I have a 38mm external Tial wastegate too) which makes adjusting boost levels a pain
Race Idiot wrote:Gee Man wrote:As above really, what power is your mr2 kicking out as a daily drive??
I'll start
350bhp
Was the mileage any worse than with the standard fuel system and turbo? Also any differences using the pfc? I was a bit worried that it doesnt do anything if you get knock.
I was tempted to get a TD06 and some bigger injectors and run with a pfc but then I thought it wouldnt be reliable for day to day use.
Although tbh my car is fast enough for me now!
sjm1984 wrote:how do you compare the 2 turbo's? what buzz do/did you get from them?![]()
Kongaroo wrote:
Pure BHP potential and therefore raw acceleration is obviously better with the TD06![]()
Race Idiot wrote:When did you start using winter tyres and when did you take em off.I've been thinking about getting a set but then i'm not sure what i'd do with my lightly used GSD3's on my winter wheels.
I'm just hoping it doesnt snow or if it does i'll work at home or something.
I was realy interested in the GT28 untill I heard people having creep issues with them.I thought the EWGT solved the problem in most cases, what make is your kit?
