[Mk2] [Turbo] missfire under load
daiodavies
Post by daiodavies »
hi all i got a little problem with my tubby missfiring under load,it idles perfect even with a little throttle,ive changed the plugs,dizzy cap and rotor arm and checked vacume pipes for leaks,plz help!!!!!!!!!
3S Service Centre
Re: [Mk2] [Turbo] missfire under load
Post by 3S Service Centre »
Hey mate check your coil for cracks, we are seeing alot of coil issues at the moment, as they get old the plastic outer cracks letting in moisture.
James
daiodavies
ile try that thanx just thought it would constantly missfire if it was the coil.anything is worth a try
RobCrezz
Post by RobCrezz »
What leads do you have? Magnacore King lead caused the same problem for me - back to toyota leads now.
daiodavies
ive got standard leads but i think im gonna try a new set.thanx bud
Jonnie1987
Post by Jonnie1987 »
Ive got the same problem but misses only on full boost, Im thinking nakered plugs. Changed the dizzy, rotor arm, plugs and leads a while ago but May have ordered N/A plugs :?
Freebird
Post by Freebird »
I'd put money on the coil, had the same thing a few weeks back and took the coil off to find some big cracks in it new one fitted $80NZ and its all good now :lol:
